.::UrbanPK::.: Lahore: Boulevard Heights - .::UrbanPK::.
Latest news:
  • (3 Pages)
  • 1
  • 2
  • 3
  • You cannot start a new topic
  • You cannot reply to this topic
Lahore: Boulevard Heights Landmark Consultants Int'l Rate Topic: ****- 3 Votes
#1 User is offline   Tekno Arkitect Icon
  • Arkitect I Urbanist I Photographer I Cyclist
  • Icon
  • Group: Management
Posted 22 June 2006 - 09:22 AM
Boulevard Heights
Designed by: Arch. Khalid Abdur Rehman [Landmark Consultants Int'l]
Status: Under Construction
Developers: Ahad Developers
Contractors: Interhom Construction Ltd.
Building Type: Commercial + Corporate + Residential
Height: 204'-0" Building Height, 230'-0" Skyline
Floors Above Ground: 19
Floors Under Ground: 5
Shopping Floors: 5
Entertainment Floor: 1
Appartment Floors: 14
Office Floors: 14
Parking Floors: 4
Rendering
Front Elevation
Bird Eye View
Description
Introduction:
Salient Feature:
This post has been edited by Techno-Architect: 25 September 2008 - 09:55 PM
Reason for edit: Renders Uploaded!
Professional Architectural Photographer - Developing Pakistan's Single Largest Architectural Database at UrbanPk.com
Critical Mass Events now in Pakistan! Come join us!
Dont just see the pix, gives your comments n critics, they are important![/color]
0
#2 User is offline   Abdullah Hayat Icon
  • Naib Zila Nazim
  • PipPipPipPipPipPip
  • Group: Members
Posted 06 July 2006 - 10:11 PM
Salam,
Techno! It says:
Shopping Floors: 6
Office Floors: 14
Parking Floors: 4
Total Floors Above Ground: 18
I am a little bit confused. Does this mean that we would have 14+6=20 floors + parking..? If so, then it says 18 floor above ground. Would that mean, 2 "Shopping Floors" would be under-ground?? That would be a new concept ... if true!
Can you please confirm from your archives??
Peace.
0
#3 User is offline   Suhaib Icon
  • Naib Tehsil Nazim
  • Group: Members
Posted 07 July 2006 - 03:49 PM
i think its 19 floors above ground and ahad developers arnt construters
0
#4 User is offline   shadow Icon
  • Citizen
  • Pip
  • Group: Members
Posted 13 July 2006 - 10:44 PM
wats the expected completion date of the project
0
#5 User is offline   Suhaib Icon
  • Naib Tehsil Nazim
  • Group: Members
Posted 14 July 2006 - 01:12 AM
end 2008
0
#6 User is offline   Tekno Arkitect Icon
  • Icon
  • Group: Management
Posted 14 July 2006 - 03:59 PM
View Postmerijanpakistan, on Jul 7 2006, 08:11 AM, said:
Salam,
Techno! It says:
Shopping Floors: 6
Office Floors: 14
Parking Floors: 4
Peace.
Well Actually the confusion was between the rendering and the information given on the brosshure.
The number of floors above ground is 19. If you see both the renderings then u wil be able to understand.
Shopping Floors Above Ground: 4
Appartment Floors/Office Floors: 14
Entertainment Floor (green one): 1
Shopping Floors Below Ground (lower ground floor): 1
Parking Floors: 4
Total Floors Below Ground: 5
With the coming of the concept of 'exposed basement' or increasing the level of the basement comes the idea of "lower basement", but 'lower basement' is not considered to be a part of floors above ground.
0
#7 User is offline   Tekno Arkitect Icon
  • Icon
  • Group: Management
Post icon  Posted 31 July 2006 - 04:20 PM
Construction Pix May 2006
Work in Progress at all levels below Ground Floor height 5 feet
0
#8 User is offline   Tekno Arkitect Icon
  • Icon
  • Group: Management
Posted 31 July 2006 - 04:32 PM
Improved Formwork designed especially to give the curves in the atrium
The circular surface in the atrium
The steel rods are joined together in the form of a mesh.
All the utility pipes are then fixed within the mesh.
Concrete is then poured onto the mesh
Workers busy spreading the concrete over the mesh
The depth of the concrete poured is check with this metalic strip which has a cross at the bottom. the horizontal part of the cross will tell whether the concrete poured is less than or more than the amount required to be poured in the slab. the concrete is mixed with the help of a small vibrator, either a mechanical one or an electrical one. Vibrating the mixture helps to prevent honeycombing in the concrete.Posted Image
Once the concrete is poured, the surface is smoothed with the help of tools like a metallic rod to give the surface a smooth texture. The tool is called 'garmala' in the local language.
0
#9 User is offline   Tekno Arkitect Icon
  • Icon
  • Group: Management
Posted 31 July 2006 - 04:48 PM
2nd Basement - the pillars are about 30-36 in diameter. The disadvantage in designing a RCC highrise building is that the pillars at the base have to be very wide and therefore they take large space. Steel structures do no face such a problem in the superstructure.
Roof being supported by steel rods......Basement 2
Ramp going out....
Lift well
stairs being built around the lift well
opening to services in the lift stairs
0
#10 User is offline   Nauman Icon
  • Union Nazim
  • PipPipPip
  • Group: Members
Posted 01 August 2006 - 12:47 AM
Has the work resumed on this?
0
#11 User is offline   Suhaib Icon
  • Naib Tehsil Nazim
  • Group: Members
Posted 01 August 2006 - 12:27 PM
the tower is nice but the mall is soo shityyy.
0
#12 User is offline   Tekno Arkitect Icon
  • Icon
  • Group: Management
Posted 01 August 2006 - 02:15 PM
Im not sure about the current status. I juss came to lahore 3 days ago. :P
0
#13 User is offline   Tekno Arkitect Icon
  • Icon
  • Group: Management
Posted 01 August 2006 - 02:22 PM
Can u define shitty? Is it the space planning of the shops your are taking or what! The construction work hasnt reached the plinth level +5 feet that is and there mall area is going to b started once the substructure gets completed. What makes the mall shitty then.
0
#14 User is offline   Nauman Icon
  • Union Nazim
  • PipPipPip
  • Group: Members
Posted 27 September 2006 - 07:12 AM
Well I passed its site today and work seems to be going on at snails pace.
0
#15 User is offline   Jilawatan Icon
  • Dictator Sahib
  • PipPipPipPipPipPipPipPipPipPip
  • Group: Members
Posted 27 September 2006 - 01:50 PM
As long as it is going on I do not see a problem.
0
#16 User is offline   Tekno Arkitect Icon
  • Icon
  • Group: Management
Posted 18 June 2007 - 05:44 PM
Consrtruction Pix MAY 2007
:dots:
0
#17 User is offline   Tekno Arkitect Icon
  • Icon
  • Group: Management
Posted 18 June 2007 - 05:47 PM
A very lazy project! Will complete by 2010 or later!!! I pray they pick up some pace like the ISE tower!
0
#18 User is offline   haawas Icon
  • Naib Tehsil Nazim
  • Group: Members
Posted 18 June 2007 - 10:55 PM
if iam not wrong they were going at very fast pace but, the constuction has been stopped by high court or supreme for last 9-10 months they were given permission to complete there basements which they have already done so cant start construction until stay order is removed
PakiDoperz--- A New Dawn For A New Generation
Movies.. Appz.. Gamez .. Muziq .. Entertainment
0
#19 User is offline   acid00 Icon
  • Union Nazim
  • PipPipPip
  • Group: Members
Posted 19 June 2007 - 02:24 AM
why the HELL were they given a star order
0
#20 User is offline   caligula Icon
  • Citizen
  • Pip
  • Group: Members
Posted 12 July 2007 - 07:52 AM
The construction was stayed because excavation work had seriously damaged an adjoining townhouse. When the homeowner sued for damages, it became apparent that the LDA has no structural safety guidelines. Then it was discovered that other buildings were taking advantage of loopholes in LDA regulations are were building in violation of bye-laws. Then the SC stayed the construction of all high rises in the city (but then gave permission to developers to raise construction up to plinth level.
Then the SC formed a commission to investigate the enforcement of LDA bye-laws. When the report was submitted, the SC ordered the destruction of those structures in violation of building bye-laws. Masood Hospital, Ahad Heights and Salaar Center have been affected.
Meanwhile, because of safety standards, work at the Boulevard Heights remains stayed.
Caligula.
0
  • (3 Pages)
  • 1
  • 2
  • 3
Ads
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
